pict
2004 Jeep Grand Cherokee Brake Disc and Pad Kit SureStop Jeep Brake Disc and Pad Kit 51OEREP21
SURESTOP OE REPLACEMENT BRAKE DISC AND PAD KITSReplacing your brakes is an investment, so if you choose to restore your stock brakes use the OE replacement brake disc and pad kit by SureStop and enjoy cost savings, better stopping power and a lot less dust and noise. SureStop is a leader in high performing yet affordable replacement brakes that meet strict OE quality standards for the ultimate in safety and performance.SureStop Semi-metallic pads have a higher friction coefficient than competing brandsSureStop shims feature dual rubber layers instead of steel for 6 times less noisePad surfaces are thermal-scorched for fast break-inMeet factory specificationsLow-dust formula for cleaner wheelsRotors and pads includedSureStop brake kit is less expensive than doing brakes at a dealership or buying premium aftermarket brakes
Get Best Price »
Price comparison
Store Price
AutoPartsWarehouse [show price]
2004 Jeep Grand Cherokee Brake Disc and Pad Kit SureStop Jeep Brake Disc and Pad Kit 51OEREP21 Review
The 2004 Jeep Grand Cherokee Brake Disc and Pad Kit SureStop Jeep Brake Disc and Pad Kit 51OEREP21 is the by far the most amazing brake pads i have seen so far. SureStop as it should make excelent product and this is one of them.
Read more reviews »
