A1 CARDONE POWER STEERING PUMPReturn the steering power of your vehicle with A1 Cardone Power Steering Pump. This high quality power steering pump provides easy power to your steering so you won't have any problems in steering your vehicle to any direction.Features and Benefits:To ensure product reliability, all critical components are triple testedBuilt with 100 percent new O-rings and premium grade and tough Viton seals to avoid leaksShafts are surfaced to OE specifications to prevent premature seal wear and extend pump lifeComputer tested to measure pressure, bypass, fluid flow, valve operation, steering effort, and noise for top notch performance
Store | Price |
AutoPartsWarehouse | [show price] |
I was seriously considering returning my 1991 Jeep Grand Wagoneer Power Steering Pump A1 Cardone Jeep Power Steering Pump 20-9989, but now I used to it. I think for 39.27 is good enough.
